Old 04-08-2019, 10:44 PM   #1
fiddy6
Default 2 speed ford-o-matic
Hi Barners,
I've an opportunity to buy 2 speed ford-o-matic supposedly from a 1960 Galaxie. I own a 56 Victoria with the stock air-cooled 3 speed auto.
The stock 3 speed is leaking trans fluid pretty hard and I want to pull it out for a rebuild/repair.
My question is, could I chuck in this 2 speeder easily to keep the car on the road or will there be irreversible modifications required to install it.
thanks in advance.
fiddy6 is offline   Reply With Quote
Old 04-09-2019, 06:21 AM   #2
darrell
Default Re: 2 speed ford-o-matic
not easily.you need to change the yoke on your driveshaft and im not sure if its the same lenght.you need the flywheel for the 2 speed.not sure about mount.i wouldnt bother unless i was going to leave it in there.
darrell is offline   Reply With Quote
Old 04-09-2019, 11:24 AM   #3
rotorwrench
rotorwrench's Avatar
Most aluminum case 2-speeds were set up for the early small block pattern bell housing for 221/260 engines or light 6-cylinders like early Falcons had. A person would have to make sure it will fit the Y-block bell pattern. The torque convert will have to fit the crankshaft end as well with the correct starter flex plate.
Old 04-09-2019, 04:16 PM   #4
fiddy6
Noted. I agree.
Old 04-09-2019, 04:18 PM   #5
fiddy6
The box is currently on the back of a 292 2V y block
Old 04-09-2019, 04:19 PM   #6
fiddy6
https://www.trademe.co.nz/motors/car...2011848111.htm
Old 04-09-2019, 04:52 PM   #7
darrell
a friend has one in a 56 its been awile since i was under it but im sure it had mount work done as well.way to much work for something your pulling back out.
Old 04-09-2019, 07:48 PM   #8
paul2748
paul2748's Avatar
If I remember correctly, the two speeds came out in 59 and were used for a few more years behind a Yblock.
The earlier fordo's are better in my opinion, was a 3 speed even though normally it started off in second.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-09-2019, 08:52 PM   #9
Daves55Sedan
Daves55Sedan's Avatar
Even if it were easy enough and happened to be a direct bolt-in, have you though about how you would select the gears in the Ford-o-Matic, since you have a manual transmission steering column in your car, right?
Old 04-10-2019, 02:59 AM   #10
fiddy6
sorry I should have been clearer... I have one of the air-cooled 3 speed ford-o-matics... probably one of the last air-cooled ford-o-matics for 56.
Its does start in "2nd" and shifts to "3rd". first only gets used if you give it the jandle from a standing start or your select it on the shifter.
Old 04-10-2019, 10:44 AM   #11
scicala
scicala's Avatar
You will also have to add an oil cooler for the trans in front of the radiator, or change radiators to one set up with a cooler in the bottom tank.
Sal
scicala is offline   Reply With Quote
Old 04-10-2019, 08:00 PM   #12
paul2748
paul2748's Avatar
I've run inline cooler attached to the frame underneath the car on two cars with no apparent problems.
48 Ford Conv
56 Tbird
54 Ford Victoria
