Old 03-14-2019, 02:05 PM   #1
adileo
adileo's Avatar
Default Oil change
Hi guys
On my 39 coupe (no filter) I change oil every 1k.
What’s suggested interval for 51 F1 with filter?
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 03-14-2019, 02:19 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Oil change
Here's a bunch of opinions.
https://www.fordbarn.com/forum/showt...nge+oil+filter
Old 03-14-2019, 02:40 PM   #3
estout81
Per the '48 owners manual every 2500 miles.
estout81 is offline   Reply With Quote
Old 03-14-2019, 03:38 PM   #4
tubman
tubman's Avatar
The interesting thing about this is that, while the oil change interval is stated as 2500 miles, the owners manual (at least for my 1951 car) calls out a chassis lube at every 1000 miles. I can't believe a truck (the way they were used) would be any more.
Old 03-14-2019, 05:29 PM   #5
estout81
We're talking oil change not lub. job.
Old 03-14-2019, 05:47 PM   #6
tubman
tubman's Avatar
I know. I just mentioned it because it is much shorter than the oil change interval and most people don't know it. But they should.
Old 03-14-2019, 06:32 PM   #7
adileo
adileo's Avatar
Interesting, I’ll go some what in between and change at 2k. Thanks
I also didn’t know lube every 1k. I’ll hit that more often- thanks
Thanks
Andy
1952 F1
Old 03-14-2019, 06:36 PM   #8
Jack E/NJ
Jack E/NJ's Avatar
Anybody who is somebody knows the answer. Looks like adileo is finally somebody. 8^) Jack E/NJ
Old 03-14-2019, 07:22 PM   #9
paul2748
paul2748's Avatar
It seems to me that with the quality of today's oils, even 3,000 without a filter is not bad.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-14-2019, 10:24 PM   #10
TomT/Williamsburg
TomT/Williamsburg's Avatar
I do not run an oil filter as well and I’ve done 3k plus when on my LA Roadster trip - changed it in Pueblo, CO on my way back. That was probably closer to 4K actually ......
TomT/Williamsburg is offline   Reply With Quote
Old 03-15-2019, 05:53 AM   #11
51 MERC-CT
51 MERC-CT's Avatar
Seems that applying oil change intervals as set forth back when the oil was inferior to the oil that is available today should be taken into consideration.
Old 03-15-2019, 11:22 AM   #12
Scotty's 52 F3
Scotty's 52 F3's Avatar
Oil lab results will give the best indication of what it should be. Most of us just don't do it.
Scotty's 52 F3 is offline   Reply With Quote
Old 03-15-2019, 05:25 PM   #13
Ross F-1
Ross F-1's Avatar
I sent my oil for analysis after a 3500 mile trip plus some local driving (maybe 500 miles). Mobil1 in a clean, recently rebuilt engine. I run a filter with a NAPA Gold element.
The analysis showed the oil was in very good condition, no need to change it on any of their criteria. See attached.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 03-15-2019, 07:01 PM   #14
51 MERC-CT
51 MERC-CT's Avatar
Don't know if I am reading the report right but are they saying to leave the oil in and check it again in 5000 miles ?
Old 03-15-2019, 08:22 PM   #15
Ross F-1
Ross F-1's Avatar
They knew I'd changed it for the analysis, so what they meant was, "Run the new oil for 5000 miles and have it tested".
Old 03-16-2019, 07:46 PM   #16
1927Tudor
1927Tudor's Avatar
I use one of these.....
http://www.lubricheck.com/
1927Tudor is offline   Reply With Quote
Old 03-16-2019, 08:17 PM   #17
51 MERC-CT
51 MERC-CT's Avatar
These units probably work well but those in the flathead community who use oil with ZINC or use ZINC additive may want to pay attention to this statement by the manufacturer of the tester.
"Some specialty or extended use oils with high levels of additives, or with metals such as zinc or molybdenum, may give falsely negative results. Examples include the Amsoil 'Signature' series , Redline oils, Castrol TWS and specialty, non API rated Royal Purple oils."
Old 03-17-2019, 12:46 AM   #18
Brian
Brian's Avatar
I run a 95% oil filter setup and still change oil at 1000 miles or less. I grease the steering components at half that. In my opinion oil and grease changes are cheap preventative maintenance.
Old 03-17-2019, 02:41 AM   #19
Jewishist
On such machines, the more often the change the better. Selected option 1K is just great.
Jewishist is offline   Reply With Quote
Old 03-17-2019, 03:38 PM   #20
34billct
34billct's Avatar
One of the benefits of modern oils is the detergents that keep dirt in suspension until removed by the filter. But with no filter I would run non detergent oil and change more often.
34billct is offline   Reply With Quote
