Old 03-15-2019, 02:11 PM   #1
Richardtx
Default 40 Ford serial # location
Looking for serial # location. Was told it was on frame next to steering box. I cleaned the frame about 8" and no sign of numbers. Is there another place to look for numbers? Thanks in advance.
Richardtx is offline   Reply With Quote
Old 03-15-2019, 02:18 PM   #2
skidmarks
skidmarks's Avatar
Default Re: 40 Ford serial # location
Top of the transmission if original.
On the frame clean it all they way up to the front crossmember from the firewall. It varies in location.
Is it the original frame ?
skidmarks is offline   Reply With Quote
Old 03-15-2019, 02:19 PM   #3
rockfla
rockfla's Avatar
Should be left side right by the firewall on the frame and also on the transmission bell housing under the front floor board of the car (IF matching)
Old 03-15-2019, 03:04 PM   #4
4dFord/SC
4dFord/SC's Avatar
FYI, here's a useful site for information on early Ford serial numbers: http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm
4dFord/SC is offline   Reply With Quote
Old 03-15-2019, 03:30 PM   #5
deuce_roadster
deuce_roadster's Avatar
My 40 coupe and wagon have the number closer to the front x member then the firewall.
Old 03-15-2019, 03:49 PM   #6
Richardtx
Thanks for all your help. Will look further to front.
Old 03-15-2019, 07:27 PM   #7
TJ
TJ's Avatar
I've had several '40s and always found the SN# right near the front crossmember on top of the left frame rail.
Old 03-15-2019, 09:14 PM   #8
Kube
Super Moderator
Kube's Avatar
I've had quite literally dozens of '39 & '40 Fords. Nearly all had the number close to the cross member.
However, there was an occasional vehicle that had the number almost next to the firewall and more than a few that had it directly beneath the horns.
I believe the number was supposed to be near the cross member.
Remember that these numbers were hand stamped by humans so no doubt, they (numbers) didn't always go where they were supposed to go.
Old 03-16-2019, 08:10 AM   #9
fourtydlx
fourtydlx's Avatar
Send a message via Yahoo to fourtydlx
Mine has 3, one at front one more at kick up ,and one at top .
fourtydlx is offline   Reply With Quote
Old 03-16-2019, 09:20 AM   #10
Kube
Super Moderator
Kube's Avatar
That's correct. Two of them can't be seen (as you know) when the body is on the frame.
Old 03-16-2019, 10:09 AM   #11
rotorwrench
rotorwrench's Avatar
Different assembly plants had different people doing the stamping too. They all likely had instructions laid down by the head shed in Dearborn but that doesn't mean the instructions were well followed to a T.
