Old 03-11-2019, 09:10 PM   #1
Sid
Sid's Avatar
Default 59AB head stud question
I just freshened up a 59AB. Installed Navarro heads. New ARP studs. I used the ARP thread sealer. I gooped the hell out of the studs. Fired engine up and have about 15 total weepers. Not spraying but weeping. I have pulled 1 stud from each head and you would probably say I'm lying about gooping these studs. Very little remaining on the studs. I am going to go the Permatex route. I have also heard some people having success using a camphor flat washer and an o ring. Question is which is better choice. Permatex #2 from the tube Permatex 80017 (Avaition) in the can which is pretty runny or Indian head Permatex??? Anybody have any thoughts on the o ring camphored washer trick. I am plannind on pulling 1 stud at a time and re torque then move to the next one.
Sid is offline   Reply With Quote
