Old 01-31-2019, 12:03 PM   #1
tjaybo
Default front gravel pan paint
Was there a standard color for the gravel pan on 55 fairlane club sedans. or, were they body color. Thanks
tjaybo is offline   Reply With Quote
Old 01-31-2019, 12:11 PM   #2
fordrodsteven
fordrodsteven's Avatar
Default Re: front gravel pan paint
Someone asked a very similar question over at the Vintage Thunderbird web site regarding the color to use behind the grill and in the gravel pan area. I would think the full size cars received the same treatment. The answer that came back was that it should be black.
David Tulowitzki said the following; The lower panel behind grill with the inspection plate as well as the grills for the fresh air intakes are to be painted black. Most restorers use a gloss black
fordrodsteven is offline   Reply With Quote
Old 01-31-2019, 07:47 PM   #3
scicala
scicala's Avatar
Maybe for Thunderbirds it was black, but the correct color on '55 Ford passenger cars is an argent silver. With a semi-gloss I think.
Sal
scicala is offline   Reply With Quote
Old 01-31-2019, 10:26 PM   #4
Bleach
Bleach's Avatar
Argent is also used on the '56 sedans as well.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Bleach is offline   Reply With Quote
Old 02-01-2019, 12:10 AM   #5
Daves55Sedan
Daves55Sedan's Avatar
Fomoco used Argent Silver for the front splash pan for all full-size cars and wagons 1949 thru 1959. Maybe some later years too, but I don't know about newer cars. Some of the resto parts suppliers sell Argent silver enamel in spray cans. It has excellent durability.
Old 02-01-2019, 09:35 AM   #6
Big Red 51
Big Red 51's Avatar
You got it Dave, My '51 thru '54 cars had the argent silver. Don
Big Red 51 is offline   Reply With Quote
Old 02-01-2019, 10:19 AM   #7
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Unless you're going concours, I've found 1979 Ford silver metallic looks good and original.
streetdreams is offline   Reply With Quote
Old 02-01-2019, 12:35 PM   #8
Ole Don
Ole Don's Avatar
My 54 and 55 were silver. I painted them both body color, it makes the car look lower for some reason.
Ole Don is offline   Reply With Quote
Old 02-01-2019, 01:15 PM   #9
Rusty_S85
Rusty_S85's Avatar
The filler panel under the grill was argent silver.
the two piece gravel shield under the engine how ever I believe was painted black. Mine has no original color left on it so I don't know what mine was. My '56 is kind of an odd ball as it has body color on the frame in areas that makes it seem my frame was painted body color by the factory.
Think it also depends on the factory too as some factories did things a bit different than others.
'56 Ford Fairlane Town Sedan - 292 Y8 - Ford-O-Matic
'78 Mercury Cougar XR7 - 351W - FMX
'82 Ford F150 Flairside - 302 - C6
Rusty_S85 is offline   Reply With Quote
Old 02-01-2019, 11:43 PM   #10
alt63bird
The question on the VTCI Forum really was geared toward the area behind the grille versus the apron/splash pan on a 'Bird (which isn't the same as on a full-size Ford because of the 'Bird not having a bolted-on/bolted-together front clip), and I didn't get a chance to comment on "black-out" treatment (will be adding to it after I submit this). But, yes, for full-size Fords, Argent Silver splash pan, radiator support/inner fenders black; grille cavity/fender sides behind the stainless trim I'm not as well-versed with as my '55 Vicky was all-black body with white roof, but has been in brown primer for 38 years and counting.
Alan H. Tast AIA, LEED AP BD+C
Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI)
http://www.vintagethunderbirdclub.net
Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years"
35+ year member, Crown Victoria Ass'n.
alt63bird is offline   Reply With Quote
Old 02-02-2019, 12:46 PM   #11
tjaybo
Thanks for the info, I knew you experts would know. I sure wish I hadn't lost my phone/camera with over 1000 tear down pictures!
Thanks Jim
Old 02-04-2019, 12:32 PM   #12
bobss396
bobss396's Avatar
I used argent silver on mine, think it was either a VHT or Duplicolor wheel paint. Not at all glossy, looks about right.
bobss396 is offline   Reply With Quote
