Old 05-07-2010, 07:15 PM   #1
Rumbleseat
Rumbleseat's Avatar
Default Trans options?
We're looking to swap out the trans in the '60. The 292 Yblock was gone through recently and would like something that gear wise will get down the highway a bit better.
Anybody have any suggestions or advice for an upgrade without having to break the bank?
Thanks,
Jerry
Rumbleseat is offline   Reply With Quote
Old 05-07-2010, 07:31 PM   #2
raceron1120
raceron1120's Avatar
Default Re: Trans options?
What do you have in it now? My '56 had a 3spd in it, I swapped it for a toploader 4spd out of a '66 Comet that I had so I don't know how much one would cost. I replaced the original POS ford shifter with a Hurst. Haven't put enough miles on it to know what kind of mileage it'll get but it'll pull out pretty good behind the Yblock.
ron
raceron1120 is offline   Reply With Quote
Old 05-07-2010, 07:55 PM   #3
Rumbleseat
Rumbleseat's Avatar
Thanks for the info. I believe it's a two speed cruisomatic.
Old 05-07-2010, 08:39 PM   #4
frank long island
frank long island's Avatar
Thanks,
Jerry
i have a 55 merc wagon with an S 10 5 speed all that was needed was an adapter and a clutch disk make a shim for the stock
throw out bearing and your good to go get an older unit or you will have to change the tailshaft for the speedo gear newer units are electronic
frank long island is offline   Reply With Quote
Old 05-07-2010, 09:25 PM   #5
Retro Jim
Retro Jim's Avatar
Well I do know there are some C-4 adapters along with an adapter for a T-5 swap . Trans Dapt and John Mummert has adapters for both . I also have seen one for an early AOD , the one without the computer shift . You have many good upgrades to replace what you have now !
Jim
Retro Jim is offline   Reply With Quote
Old 05-07-2010, 09:50 PM   #6
paul2748
paul2748's Avatar
Thanks,
Jerry
If you are looking for gas mileage on longer trips, the obvious choice would be an AOD if you want an automatic or 5 speed of you want a standard shift.
If not interested in an overdrive trans, the top loader four speed or a C-4 would be good choices.
Last but not least would be a stock three speed with overdrive.
Old 05-08-2010, 08:51 AM   #7
mctim64
mctim64's Avatar
If you have an auto. go with the AOD, adaptors are out there, if you have a manual the T-5 is the way to go. T-5 is what I have in my pickup. BSC in Costa Mesa advertises in Y-Block Mag for AOD conversions 949 722 1122 no website.
mctim64 is offline   Reply With Quote
Old 05-08-2010, 11:08 AM   #8
ripper57
I used a T-5 from a mustang V-6 but put the S-10 tailshaft to move the floor shift forward away from the seat. Been driving it over a year and love it ! (1954 Sunliner)
ripper
ripper57 is offline   Reply With Quote
Old 05-08-2010, 11:49 AM   #9
Rumbleseat
Rumbleseat's Avatar
Thanks for the help gang. Yes, mostly looking to get some highway mileage out of the upgrade. AOD is probably the route to take.
The car is actually an Edsel (my brothers). Yes, a very rare '60 Edsel wagon, and a hole in the floor really isn't an option. To all the purist, I promise ALL changes made to the car can be easily reversed and brought back to stock.
Old 05-08-2010, 12:02 PM   #10
havi
havi's Avatar
Bendtsen has an AOD to Y block adapter, but they ain't cheap.
I'm just an old truck guy trapped in a hotrodder's world.
havi is offline   Reply With Quote
Old 05-08-2010, 01:47 PM   #11
Rumbleseat
Rumbleseat's Avatar
$850.00
Old 05-08-2010, 02:04 PM   #12
JeffB2
JeffB2's Avatar
The more frugal option if your present transmission is OK is to change rear gears,since it is a 9" those are usually fairly inexpensive as the racers usually swap them out to get a stouter gear,a 3.00 is not hard to find.
JeffB2 is offline   Reply With Quote
Old 05-08-2010, 08:12 PM   #13
parklane
parklane's Avatar
Or a 2:79
parklane is offline   Reply With Quote
Old 05-08-2010, 11:22 PM   #14
aaron griffey
Send a message via Yahoo to aaron griffey
I have a 3 speed with overdrive from a '61 that is for sale.
Aaron (510)415-1219.
aaron griffey is offline   Reply With Quote
Old 05-11-2010, 09:42 PM   #15
Grandadeo
Grandadeo's Avatar
Aaron, just curious if that is a T-86/R10 or a T-85/R-11, or maybe even something else. I trying to do some fact finding on the different 3 speed overdrive Ford transmissions. Thanks.
Lee
Salt Is Good... Mk 9:50
Grandadeo is offline   Reply With Quote
Old 05-12-2010, 01:58 AM   #16
ken ct
Rumble seat? How come your location is listed as Fruitport,Mi. Did you move out of Colo.?? just curious? ken ct.
ken ct is offline   Reply With Quote
Old 05-12-2010, 08:04 AM   #17
40cpe
40cpe's Avatar
Ken, I think this is another Rumbleseat
Old 05-12-2010, 09:27 AM   #18
mctim64
mctim64's Avatar
I bought a C-4 adaptor from Mummert for my Y-Block FED. $500 Nice kit, had everything I needed.
Old 05-19-2010, 12:14 PM   #19
0rg0
0rg0's Avatar
The car is actually an Edsel (my brothers). Yes, a very rare '60 Edsel wagon, and a hole in the floor really isn't an option. To all the purist, I promise ALL changes made to the car can be easily reversed and brought back to stock.[/QUOTE]
I have an AOD in my '59 Edsel, and it made a huge different to the performance of the car. Having the overdrive is awesome. Get yourself a Lokar tv cable, and you'll need to build some kind of Trans crossmember. Other than that it's easy.
0rg0 is offline   Reply With Quote
Old 05-19-2010, 03:11 PM   #20
Gerry
Gerry's Avatar
I have an FMX behind a 292 in a 54 Sunliner A simple conversion and still a basic stock car. Don't know if this is what you are looking for but runs great in my car. Gerry
Gerry is offline   Reply With Quote
