Old 01-20-2019, 12:45 AM   #1
Lawrie
Lawrie's Avatar
Default strange crankshaft
I pulled apart a low mileage 99a engine, all standard,great rods,still on the standard size,std crank and bore (but a big crack in one),
It has this funny crankshaft ,with the clean out plugs on the outside of the crank,not one the side,
all the pistons have FORD Canada on them.
Any one seen one like it .
Lawrie
Old 01-20-2019, 12:56 AM   #2
ford38v8
ford38v8's Avatar
Default Re: strange crankshaft
Lawrie, this link to a Bill Boomer article on crankshafts may be of help to you.
http://www.goldengatev8.org/docs/merccrankid.pdf
Alan
Old 01-20-2019, 12:56 AM   #3
Brian
Brian's Avatar
Yes, Someone on fordbarn posted photos of the same style crankshaft a coupla years back.
Old 01-20-2019, 01:49 AM   #4
40 Deluxe
Well, no chance of it being a 4" Merc crank! It only has one oil hole per throw!
Old 01-20-2019, 11:16 AM   #5
rotorwrench
rotorwrench's Avatar
The Windsor, Ontario foundry did things differently than the Rouge. That may have been a Canadian wartime engine. This is where I still have a lot to learn about just what was different in the Canadian engines versus USA engines. Most all USA engines had the clean outs. That may have been a Canadian version. It lightened the crank and provided a last chance centrifugal filtering system for the con rod bearings. I also don't know of any aftermarket crankshafts but it might be possible.
Old 01-20-2019, 11:47 AM   #6
KiWinUS
KiWinUS's Avatar
I have a crank like that also , came in the first flathead I brought when just 15 & still have it. My engine would have been built in Canada I believe. It will get built this year but with a 4 1/8" crank, already have it cleaned & have sonic checked it. Has "19" cast into right front of block , factory relieved, 3 3/16 +.060 & bores are close to .157" thick everywhere I checked it. It will get bored to 3.375
Cheers
Tony
KiWinUS is online now   Reply With Quote
Old 01-20-2019, 12:14 PM   #7
Ol' Ron
Ol' Ron's Avatar
Never seen one like it. Seen a few 4" cranks with small clean out plugs tho.
Old 01-20-2019, 03:28 PM   #8
macdonge
macdonge's Avatar
I have a Canadian-built 99 engine (keystone block, see my avatar) with the original crank. No such cleanouts on mine.
macdonge is offline   Reply With Quote
Old 01-20-2019, 03:30 PM   #9
Lawrie
Lawrie's Avatar
I think Kiwi has it,as the engine has ford canada pistons,is still standard bores they would be original you would think.
and most stuff here in Australia came from Canada.
Lawrie
Old 01-20-2019, 03:37 PM   #10
KiWinUS
KiWinUS's Avatar
I believe mine even has the same square head pipe plug.
Old 01-20-2019, 05:19 PM   #11
VeryTangled
VeryTangled's Avatar
Cheers
Tony
Epic. Okay Now you guys are making me wipe my eyes!
-Jeff H
Old 01-20-2019, 10:36 PM   #12
Brian
Brian's Avatar
Here you go...I said I'd seen a thread on here previously about this style crankshaft;
https://www.fordbarn.com/forum/showt...ugs+crankshaft
Old 01-21-2019, 01:35 AM   #13
Lawrie
Lawrie's Avatar
Brian I have a couple of blocks with the oil passage coming across from just above the engine stay rod hole on the bell housing.
None drilled though.
I looked at the one on the engine I,m doing at the moment and tried to work out how to make it work with a filter,
I think that the rear main stayed in the circuit from the pump before the filter or cooler.
Lawrie
Old 01-21-2019, 03:50 AM   #14
Brian
Brian's Avatar
The French blocks have an oil hole eminating from that position
Old 01-21-2019, 06:59 AM   #15
4tford
4tford's Avatar
I have 2 of those. One NOS came in this crate
4tford is offline   Reply With Quote
