Old 01-13-2019, 09:02 PM   #1
modeleh
modeleh's Avatar
Default Weiand 8.75 Heads
I have a set of Weiand heads 8.75 stamped at water neck. They are 59a style so I presume the CR was calculated based on a 239. What are your opinions on installing them on a 8ba standard bore with 4” crank? I have read that Flatheads don’t work great past around 9:1
If a guy were to build a 276 would you run these heads?
modeleh is offline   Reply With Quote
