Old 11-08-2018, 04:21 PM   #11
philipswanson
Default Re: Optima 6V batteries production
Originally Posted by ford38v8 View Post
They are worth it, yes. Your bunch of lead acid batteries will each damage your car with acid vapor as they charge. The Optima doesn't normally outgas beyond the mat.
In 78 years of using lead acid batteries in my car, damage never happened. Not if you clean the area once in a while. I use an Optima in my Vette because they put the computer under the battery (dumb as GM) but never in any of my many cars. There is also an AGM option other than an expensive Optima.
philipswanson is offline   Reply With Quote
