#23 |
The engine has a Eubank cast nodular (ductile) iron model B balanced crank, in a Model A block. Model B cam, inserted bearings, pressurized oil on all bearings, Stipe/Specialty Cam Hi volume oil pump for A/B engine, 25 lb. aluminum flywheel, 1939 Ford transmission with a Borg Warner overdrive. The intake is what I don’t know the manufacture of.
