08-26-2018, 04:16 PM | #1 |
Distributor wire question
I was going to swap out Dist. wires with a new unused uncut set of wires but wondered if the 6v Vs 12v would be an issue? All advice is appreiated...
08-26-2018, 05:20 PM | #2 |
Re: Distributor wire question
If you are talking about spark plug wires (no difference)
08-26-2018, 05:54 PM | #3 |
I have been around the block a few times about this. Unless it is a factory correct restoration, I always go with Packard 440 solid core wire and Rajah spark plug terminals. I get them from the Brillman Company and have never regretted it. The positive "click" you hear when putting on a Rajah terminal on a spark plug is very satisfying.
08-26-2018, 08:14 PM | #4 |
I'm a 440 & Rajah fan as well.
08-26-2018, 10:32 PM | #5 |
Electronic ignitions excluded. you want solid core... outside spiral bound resistor wire for electronic ignition.
08-27-2018, 10:44 AM | #6 |
08-27-2018, 11:20 AM | #7 |
solid core & rajah ends from Brillman.
