Old 08-22-2018, 03:12 PM   #1
AnthonyG
AnthonyG's Avatar
Default Indentify chassis?
Got a ‘40 pickup that’s modified. Believe chassis to be 1948-1956? chassis numbers hidden with brake lines & junction block too much in front of them to see. Has front dropped I front with leaf spring pads on & leafs right & left. 4 vertical cross mem’s. @ Front bumper behind tranny, approx 2’ front of rear & extreme rear where rear bumper attaches. Would like to figur year or at least confirm it’s an F1 chassis. Sorry pics a little rough.
Nomad
AnthonyG is offline   Reply With Quote
Old 08-22-2018, 03:19 PM   #2
RalphM
RalphM's Avatar
Default Re: Indentify chassis?
No pictures
RalphM is offline   Reply With Quote
Old 08-22-2018, 03:28 PM   #3
skidmarks
skidmarks's Avatar
Does it have tube shocks or lever action. The 42 to 47 frame is pretty much the same as a 48 to 52 with the exception of cross steer and lever shocks
Could be a 42 to 47 pu with a 40 41 nose. But to make it look right the cab has to be channeled or dropped. Most of the time it looks like a total disaster
skidmarks is offline   Reply With Quote
Old 08-22-2018, 03:35 PM   #4
AnthonyG
AnthonyG's Avatar
Tube shocks with parallel leafs right / left. Sorry about pics, site tells me I’m missing security token??
Nomad
Old 08-22-2018, 03:37 PM   #5
JSeery
JSeery's Avatar
How is it titled/registered? Is the serial number on the paperwork?
Old 08-22-2018, 04:09 PM   #6
Charlie Stephens
"Missing security token" are code words that usually really mean your pictures are too large. If you don't know how to downsize them PM me, or post what photo software and hardware you are using and someone will post instructions.
Charlie Stephens
Old 08-22-2018, 04:21 PM   #7
JSeery
JSeery's Avatar
The 40 and 41 frames/chassis would have a transverse rear spring. So it would have to be later if it is an original type of chassis.
Old 08-22-2018, 04:28 PM   #8
Bob C
These are from Vanpelt.
Old 08-22-2018, 05:56 PM   #9
AnthonyG
AnthonyG's Avatar
I knew it wasn’t a ‘40 or ‘41 chassis. Looks like it could be either a ‘42-‘47 or ‘48-‘51 both R very similar. I think rather than cut the stock ‘40 Chassis to fit the modern V8 & Auto Trans he changed chassis’s. Thx guys, that gets me close enough.
Nomad
Old 08-22-2018, 06:25 PM   #10
skidmarks
skidmarks's Avatar
I saw your other post with pictures. The tail gate looks like the 42 to 52 tailgate. The outer edges were the raised panels are, thats the give away. The lack of the fuel fill pipe is another clue. Look inside the cab on the passanger side and see if it had a fill pipe hole
Old 08-22-2018, 08:54 PM   #11
rich b
rich b's Avatar
Unless they switched the steering and brakes; F-1 would be side steer with Bendix brakes, while the earlier chassis would be cross steer with Lockheed brakes.
Old 08-22-2018, 09:10 PM   #12
AnthonyG
AnthonyG's Avatar
Based on Vanpelt drwg’s frame’s definitely ‘42-‘47 matched up exactly. No welded patch on cab so believe it’s a ‘40 or ‘41 cab. Front clip is ‘40 as well with a ‘41 hood. As said previously it is modified & has what looks like a Chromed speedway front dropped I-beam for F-1 w disc brakes. I think the rear is from old Camaro or firebird w leafs. Bit of a Frankenstein but love it! Very pretty Frankenstien
Nomad
Old 08-22-2018, 09:18 PM   #13
Tinker
Tinker's Avatar
Post up some pictures?
Old 08-23-2018, 01:47 AM   #14
Mart
Mart's Avatar
Pics are in this thread:
https://www.fordbarn.com/forum/showthread.php?t=249754
Old 08-23-2018, 07:03 AM   #15
AnthonyG
AnthonyG's Avatar
Sorry about quality of pics. Gotta an appt. can’t get under it & get dirty now
File Type: jpg 3BFA4D1A-8FA1-40FD-9C6C-8006F1CE774C.jpg (84.5 KB, 52 views)
File Type: jpg 506BBE83-D1EF-4CB9-8912-70FF8455C859.jpg (18.4 KB, 47 views)
File Type: jpg DBD42298-E4E5-4A98-873E-6D6E2EDBC8CC.jpg (65.8 KB, 55 views)
Nomad
Old 08-23-2018, 08:23 AM   #16
V8COOPMAN
V8COOPMAN's Avatar
That rusted-chrome, steering "thing-a-ma-jiggy" sure is spooky looking. The neat part of it all is that the NEW OWNER is happy with it. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-23-2018, 05:05 PM   #17
AnthonyG
AnthonyG's Avatar
DD definitely gotta talk to Speedway for better steering link. While it looks shaky its very solid and works, agreed steering thing-a-ma-jiggy is ughly! All the front suspension looks like chromed Speedway stuff so now that chassis is ID’ed will see what’s better & available. Their chomed suspension pieces didn’t hold up well in the previous owners garage while stored 4 23 yrs & wouldn’t have been my choice. Will clean up & do black.
Nomad
Old 08-23-2018, 05:12 PM   #18
skidmarks
skidmarks's Avatar
What kind of steering box is it?
Old 08-23-2018, 05:30 PM   #19
AnthonyG
AnthonyG's Avatar
As rich b indicated It looks like it was an early F1side steer originally. The holes still in the frame but the builder installed a power stering box mounted forward on chassis as seen from below in pic.
Nomad
Old 08-23-2018, 06:24 PM   #20
skidmarks
skidmarks's Avatar
Thats what i ment, was what kind of steering box is in it currently? Its weird the drag link hooks to the left spindle and its cross steer? Unless i am seeing it from the opposite direction.
If it had a factory hole on the left frame rail for a drag link(front to back) then the frame is a 48 to 52
