Old 07-13-2018, 10:25 AM   #1
shoe box Jack
Default oil
I have been using shell rotilla 15 40 I understand there is no more zinc in it. to-day I was in the parts store and STP in the blue label has zinc and ZDDP in it so I'm going to add a can to the shell. Has anyone tried this?. Jack
shoe box Jack is offline   Reply With Quote
Old 07-13-2018, 10:38 AM   #2
drolston
drolston's Avatar
Default Re: oil
If you think you need zinc, take a look at Valvoline VR1 20W-50 racing oil. Stocked at all parts stores, and not much more expensive that regular oil.
Old 07-13-2018, 10:46 AM   #3
Ole Don
Ole Don's Avatar
Default Re: oil
Yes, I used the STP for that reason. At that time, it was in a blue bottle.
Ole Don is offline   Reply With Quote
Old 07-13-2018, 10:56 AM   #4
tubman
tubman's Avatar
Default Re: oil
I bought a bunch of "Peak" (the anti-freeze people) oil at Dollar General for $1.85 a quart. I don't know what the zinc content was, but it was marked "Not to be used in vehicles manufactured after 1985".
Old 07-13-2018, 11:00 AM   #5
Seth Swoboda
Seth Swoboda's Avatar
Default Re: oil
I still run the Rotella T4 15-40 in all my flathead and diesel engines with no worries.
Old 07-13-2018, 11:26 AM   #6
flathead48
Default Re: oil
Penn Grade is very good, little pricey, but enough zinc.
flathead48 is offline   Reply With Quote
Old 07-13-2018, 04:48 PM   #7
VeryTangled
VeryTangled's Avatar
Default Re: oil
I have been using shell rotilla 15 40 I understand there is no more zinc in it... Jack
Originally Posted by drolston View Post
If you think you need zinc...
Hi Everyone, Not trying to stir up a hornet's nest, but what makes you want the zinc?
-Jeff H
Old 07-13-2018, 04:56 PM   #8
Ebbsspeed
Default Re: oil
Flat Tappets. It's actually a compound called ZDDP, which contains zinc and phosphorus among other components, and is a lubricant for very high pressure contact areas between metals. The cam/tappet contact area is one of those. The zinc content is oils has been slowly reduced until is/almost is non existent in most oils today. EPA restrictions.....
Ebbsspeed is offline   Reply With Quote
Old 07-13-2018, 04:59 PM   #9
40 Deluxe
Default Re: oil
All oil still has some (plenty enough for a flathead) zinc in it. Do you think oil in the '30's and '40's had zinc in it?? Nope! I've seen flatheads totally worn out, more smoke coming out of the road draft tube than the exhaust, which was pouring out blue smoke, wrist pins rattling, mains thumping, rear main pouring out oil, and the cams were fine. By the way these poor old clunkers were usually fed re-refined oil (no detergent, no zinc, no nothing).
Old 07-13-2018, 05:26 PM   #10
30aadoodlebug
30aadoodlebug's Avatar
Default Re: oil
The ZDDP is to make up for not having leaded gas. That's the point. supposedly the lead in the gas helped with tappet wear. Just what I've been told by many old-timers, some of whom were auto engineers for the big three.
30aadoodlebug is offline   Reply With Quote
Old 07-13-2018, 06:37 PM   #11
JSeery
JSeery's Avatar
Default Re: oil
Don't think so. Lead has to do with valve seats and stems, not the cam to lifter surface.
Old 07-13-2018, 06:41 PM   #12
mrtexas
mrtexas's Avatar
Default Re: oil
STP is not a lubricant, beware. Adding it makes the oil thicker
but is also diluting the oil.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 07-13-2018, 09:45 PM   #13
paul2748
paul2748's Avatar
Default Re: oil
Valvoline 10-40 has lots of Zinc in it. Recommended by a noted YBlock engine builder. He uses it in his regular and performance engines.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-13-2018, 10:13 PM   #14
flatjack9
flatjack9's Avatar
Default Re: oil
There is so much BS out there about zinc. All oils still have plenty of zinc for our flatheads. Adding it to your oil is a waste of money and in some cases can actually do harm. Forget about it.
Old 07-14-2018, 07:30 AM   #15
Timstruck
Default Re: oil
https://540ratblog.wordpress.com/
Probably more than you ever wanted to know about oil, but this blog is one of the best in my opinion. I used it to help me pick an oil for my old cars. Make sure you scroll down a good ways to find his rankings...
Timstruck is offline   Reply With Quote
Old 07-14-2018, 08:20 AM   #16
Frank Miller
Frank Miller's Avatar
Default Re: oil
I ran synthetic for 8100 miles and when I changed it had an oil analysis done. They said try 9000 next time.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 07-14-2018, 08:22 AM   #17
flatford8
flatford8's Avatar
Default Re: oil
It’s been said on here, by someone a lot smarter than me about our beloved Flatheads, just about any oil you buy today is better than what you could buy 70 plus years ago. You can pick your oil by the color on the jug if you want........ Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 07-14-2018, 08:49 AM   #18
rotorwrench
rotorwrench's Avatar
Default Re: oil
Y-blocks are in the OHV category so a little more zinc/phos would be OK for them but flatheads have large flat tappets an low spring pressures so it's not really needed. The API ratings can tell you how much zddp is in there but you have to remember that the older ones like SG are obsolete and not regulated as such. Not all modern motors have roller tappets. Some are still flat tappet and they do fine on the later 800 ppm zddp additives. It's the motors built from around 1958 through 1973 or so or hopped up engines that were high compression and high spring pressure that needed the higher 1200 ppm rated oils. This was the reason for the increase in the first place.
Old 07-14-2018, 10:13 AM   #19
JSeery
JSeery's Avatar
Default Re: oil
Yep
Old 07-14-2018, 10:41 AM   #20
Kahuna
Kahuna's Avatar
Default Re: oil
On that very good 540Rat blog, Note that Chevron supreme oil has large amounts of ZDDP, and available at my Costco store at about 4 bucks a quart.
I use 5-30 in my flathead. About the best bang for the buck
Seems to work fine
Jim
Kahuna is offline   Reply With Quote
