Old 06-18-2018, 05:21 PM   #11
George/Maine
George/Maine's Avatar
Default Re: resistor cause miss??
Most 6 volt systems run about 3 amps when running.
Measuring across resister meaning one end or other each end.
4.6 is way to high.
My guess you have a 1.5 ohm resister wrong for 6 volts.
When charging 6.8 volts minus 4.6 leaves 2.2 volts to coil look to low.
Measure the ohms on resister. should be .5 ohms. .5 x 3 amps= 1.5 volts will increase coil voltage 5 volts.
George/Maine is offline   Reply With Quote
