Old 05-18-2018, 04:06 PM   #14
4port
4port's Avatar
Default Re: New guy with questions.
Check that the crankshaft pulley is tight on the crankshaft. Two piece pulley? I bought an engine once that everyone said had a wrist pin knock, tightened the crank pulley, and it went away. I had first pulled the pan to check the rod bearings and noticed the loose pulley in the process.
4port is offline   Reply With Quote
