Old 05-02-2018, 05:25 PM   #10
jax55
jax55's Avatar
Default Re: 12V Delco alternator problem
If you look at the rear housing you will see a half moon shaped hole. There is a tab in that hole, if you ground that tab and the alternator charges.... bad regulator. Easy to replace.
Bill Williamson is correct, if you lose a diode there will be a definite sound. Still easy to replace.
Could also be you wore one of the brushes out.
All are easy to replace, once you have the parts.
jax55 is offline   Reply With Quote
