Old 01-26-2018, 06:44 PM   #25
hulleywoodworking
Default Re: Pilot bearing fit
a 6203 is 17mm Bore 40mm OD 12mm Width.
17mm bore =.66929"
What is the diameter of the shaft? A dial caliper will be accurate enough, unless you have a micrometer.
hulleywoodworking is offline   Reply With Quote
