Old 01-20-2018, 10:40 AM   #11
GordonC
Default Re: Rebuilt Flathead Problems.
Guys thanks for the additional info on using a home made tester to get the spring pressures. I will probably rig one up.
Gary what I am I looking at for a set of the bronze lined guides? Don't mind doing whatever makes sense.
Also guys I have asked this a couple times now but nobody has answered me on this yet. Do I need to worry about the different length valves? These are chevy 1.5" valves and they were anywhere from .035 under 4.9" to 4.910" length. If I can compensate for the variance using the adjustable lifter and the reground cam I can just forget about this if I can get an answer.
GordonC is offline   Reply With Quote
