Old 01-17-2018, 08:49 PM   #21
aford193031
aford193031's Avatar
Default Re: Calling all Side Mount 31 Carbs that you have
I am going to have to really watch the swap meets.
aford193031 is offline   Reply With Quote
Old 01-17-2018, 08:55 PM   #22
160B
160B's Avatar
Originally Posted by Bob C View Post
Looks like the same person but the one listed on this site says SOLD.
Maybe he took it off here and put it on Epay.
https://www.fordbarn.com/forum/showthread.php?t=237074
Bob
The location of the carburetor listed on eBay is Ringgold, Ga and the Fordbarn site location is also Ringgold, Ga.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 01-17-2018, 09:14 PM   #23
SteveB31
SteveB31's Avatar
Looks like some of my Zenith 3 carbs going on EBay soon
SteveB31 is offline   Reply With Quote
Old 01-18-2018, 11:00 AM   #24
Purdy Swoft
Purdy Swoft's Avatar
Originally Posted by Joop View Post
Here are some pictures of the Zenith and Simmons side bowl carburetors Purdy mentioned
Zenith pictured is not a 3
Thanks Joop for the good pictures . I wonder if Simmons ever made an alloy side bowl version . The alloy Simmons carbs were made for fuel economy . I've got a couple of the regular Simmons alloy carbs but have never seen a side bowl version . I'll bet that they made one .
Old 01-18-2018, 11:11 AM   #25
TerryO
TerryO's Avatar
I will vouch for the seller. He is an honest upstanding Model A guy
TerryO
TerryO is offline   Reply With Quote
Old 01-18-2018, 03:41 PM   #26
F.M.
Yes, They did..I had Two of them..
F.M. is offline   Reply With Quote
Old 01-18-2018, 06:07 PM   #27
Purdy Swoft
Thanks F.M. I've been running a regular cast iron Simmons carburetor on one of my model A's going on 12 years and I haven't had to do anything to it. It doesn't leak a drop yet. I know that its hard to believe ! All of the different updraft carbs that I have ever used, sooner or later leaked. Simmons cast iron carbs were far better that Zenith in my opinion. I've never tried the alloy Simmons .
Last edited by Purdy Swoft; 01-18-2018 at 06:14 PM. Reason: corrected a typing error.
Old 01-18-2018, 06:51 PM   #28
Bob-A
Bob-A's Avatar
Smile Re: Calling all Side Mount 31 Carbs that you have
Mr. Purdy,
I've got a June, 1933, Simmons catalog. Replacement carburetors, Part number: A-9510-B 1928-31, A-9510-C Late 1931, B-9510 4-cyl. 1932. All carbs look like they are cast iron. The alloy carbs must have come out later.
Bob-A
Bob-A is offline   Reply With Quote
Old 01-18-2018, 08:31 PM   #29
Purdy Swoft
Bob , I really don't know when they came out but you are probably right . The first Simmons carb that I got was a rough Simmons alloy . I only paid 5 dollars for it . I patched it up with whatever Zenith parts that could be fitted to it. I never got around to using it . I kept it because I figured it was sorta rare .There was some articles about different carburetors in the restorer in 94-95 and the Simmons alloy was one that was briefly mentioned . Later in 03 , I think , There was an article in the Fast magazine about how much air some of the different updraft carburetors flowed .The model B zenith was best . TheTillotson model X was said to flow second best . TheMarvel and then the Zenith one and two was the next best . The Simmons alloy was way worse than any of the others . The tests were done by an engineer with a vacume cleaner . The Cast iron Simmons wasn't tested . The Simmons alloy has a much smaller venturi and jets than the cast iron perfoprmance Simmons carb . I was allways more concerned with more power than better fuel economy . I only keep the alloy carbs because they are part of my Simmons carburetor collection . I haven't found a lot of info . The cast iron Simmons is by far my favorite up draft carburetor . Maybe someone can tell us more about the history of these carbs .
Purdy .
Old 01-18-2018, 09:19 PM   #30
David31dlxslant
David31dlxslant's Avatar
Hi, this is my Carburetor on eBay, I can assure you I don’t have my “buddies” bidding it up, I will also agree it is a little insane how much it’s going for, but it’s out of my control
David31dlxslant is offline   Reply With Quote
Old 01-18-2018, 09:22 PM   #31
Chris Haynes
Chris Haynes's Avatar
Same seller.
https://www.ebay.com/itm/Zenith-2-Si....c100005.m1851
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-18-2018, 11:29 PM   #32
Mike V. Florida
Mike V. Florida's Avatar
It's the fact that it is a "3" that makes it so rare.
Old 01-19-2018, 08:27 AM   #33
Joop
Joop's Avatar
Alloy "SIMMONS"
Last picture is the illustrious alloy side bowl (only 1 produced) ;-)))
Joop is offline   Reply With Quote
Old 01-23-2018, 11:49 AM   #34
Purdy Swoft
It doesn't have to be a Zenith 3 to be a side bowl carb . Without going out and looking I think that mine is a Zenith 1 . The first time that I ever remember mention of the Zenith 3 was when Rex Reheis found a few of them in the 90s .There was a write up in one of the national model A club mags . I think that Rex was asking around five hundred dollars for one of them. This was nearly 20 years ago and I don't think that any of them were side bowl . Zenith 3 carbs Bring huge prices because of their rarity to the right collector . I've read that the Zenith 3 was made by Ford as a replacement . I've got to wonder if the Zenith 3 came on any of the model A's or was only available as a replacement . Ford could probably make these thin delicate carbs for less than he could buy carbs from Zenith or Holley .
Old 01-23-2018, 11:49 PM   #35
RonC
RonC's Avatar
They were early to end 1931 production carbs. I think the first replacements were the 1932 production carbs.
RonC is offline   Reply With Quote
