Old 12-11-2017, 03:38 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: Rebuilt Flathead Problems.
Looks like the rebuilder put the crank gear on backwards! Thats the only reason to not see a dot on the crank gear. Its possible to correct this without removing the crank gear which is near impossible to do with the crank installed. First I would be sure the front of the crank gear is flush to the front of the cam gear if it is then i would move on to the next step. The next step requires the right side head to be removed so the piston can be located at top dead center. When this step is completed now a timing dot can be marked onto the crank gear.
The final step will be a bit more difficult moving the cam shaft to the proper position so the cam gear dot lines up with the crank gear. This step is difficult due to the fact you need to move the cam without the cam gear bolted in place turning the cam with the valve spring pressure is the hard part. To rotate the cam to the correct location I would use two long 6/16 fine thread bolts placed in two of the cam bolt holes this will give a leverage point to turn the cam which at the same time will also be working the valves. The cam gear bolt pattern is not even spaced so the proper location of the cam will be found as you check the bolt pattern to the pattern in the cam gear.
This is not a simple job but also not impossible with a little effort you will solve the problem.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
