Old 12-10-2017, 09:21 PM   #1
Midwest Tin
Midwest Tin's Avatar
Default Adding petina to a reproduction 32 Grille Emblem
Hi,
Has anyone experimented with aging or adding patina to a reproduction 32 grille emblem or chrome rad.cap to use on an original car? I would like to hear what works and what doesn't. Hopefully some one has experimented with this. Or if anyone has any ideas of what will work let me know. Thanks in advance. Jim
Midwest Tin is offline   Reply With Quote
Old 12-10-2017, 09:35 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Adding petina to a reproduction 32 Grille Emblem
You might try rubbing compound to take the shine off a repop.
Old 12-10-2017, 09:40 PM   #3
TomT/Williamsburg
TomT/Williamsburg's Avatar
I have been told to put things like that submerged in a jar of coke and check its progress ....
TomT/Williamsburg is offline   Reply With Quote
Old 12-10-2017, 09:55 PM   #4
grovesmr
I think mightycarmods did something like this on their YouTube channel. They used various methods on different panels for a somewhat scientific experiment. Salt water, beer, and urine.
grovesmr is offline   Reply With Quote
Old 12-10-2017, 09:55 PM   #5
koates
Hi Jim, Leave em up on your roof for 50 years !! Regards, Kevin.
koates is offline   Reply With Quote
Old 12-10-2017, 11:41 PM   #6
Lanny
Lanny's Avatar
Originally Posted by Midwest Tin View Post
Hi,
Just an idea.
How about getting a little bit of car battery acid from an old battery at
an auto parts store, to soak it in.
Keep an eye on it, and have some water with baking soda, to rinse with,
when it starts to resemble the look you want.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 12-10-2017, 11:54 PM   #7
FlatheadTed
FlatheadTed's Avatar
Give it a coat of clear Laquer add a few drops black maybe white give it a scotch brite rub when dry .Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-11-2017, 07:57 AM   #8
RalphM
RalphM's Avatar
Salt water brine.
RalphM is offline   Reply With Quote
Old 12-11-2017, 08:16 AM   #9
Binx
If you want a permanent tarnish experiment with this on another chrome part to see if you like it...
https://www.walmart.com/ip/The-Works...&wl13=&veh=sem
It works great to remove oil spots on concrete as well.
Lonnie
Binx is offline   Reply With Quote
Old 12-11-2017, 10:53 AM   #10
tubman
tubman's Avatar
I never did get the "fauxtina" thing. You can usually spot it from a long ways away.
Old 12-11-2017, 11:00 AM   #11
Vics Stuff
Vics Stuff's Avatar
You can put your part in a media blast cabinet and using ultra fine glass beads @ 40psi you can achieve the patina look.
Vic
Vics Stuff is offline   Reply With Quote
Old 12-11-2017, 11:26 AM   #12
jim1932
jim1932's Avatar
I do in cases where you had to buy a new part to put on your older car. The shiny sticks out big-time and screams repop.
I am not a big fan of taking a new paint job and making it look old.
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 12-11-2017, 11:39 AM   #13
40 Deluxe
Hi,
All you need is patience! Just put it on the car, ignore it, and in 15-20 years you will have your patina-genuine, not faked!
