Old 11-05-2017, 05:11 PM   #21
Floyd
Default Re: 1939 Column - Top Bushing Replace
I double vote for Dan Brussgard's "steering bearing" kit. It is It is perfect and way better than anything else. If you are going to take the time to take apart a car with a horn rod, I recommend you treat yourself to the good solution.
My opinion
Floyd is online now   Reply With Quote
Old 11-05-2017, 05:54 PM   #22
RKS.PA
RKS.PA's Avatar
I used Dan's kit in my '39 and it was perfect. At first turning the wheel did turn off the lights as JM mentions above....I thought it was the "kit" but I guess I bent the rod slightly because after a while it went away!!! I did this project as part of restoring the steering wheel and installing a new switch at the end of the rod
Dick.
RKS.PA is offline   Reply With Quote
Old 11-23-2017, 12:59 PM   #23
Bondolero
Bondolero's Avatar
Would like to purchase a needle bearing kit. Doesn't seem to be on eBay ??????
Anyone have contact info to purchase. Thank you
Larry
Bondolero is offline   Reply With Quote
Old 11-23-2017, 01:12 PM   #24
FlatheadTed
FlatheadTed's Avatar
https://www.ebay.com/itm/112651171114?ul_noapp=true
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-23-2017, 01:19 PM   #25
Bondolero
Bondolero's Avatar
thank you very much.
Old 11-24-2017, 09:14 AM   #26
Tom/SC
Tom/SC's Avatar
Ditto to Swoops posting, horn rod to horn button connection is fragile.
Tom/SC is offline   Reply With Quote
Old 11-29-2017, 01:35 PM   #27
Bondolero
Bondolero's Avatar
Needle bearing kit is well designed and made. Thank you Dan.
