Unable so far to locate cam bearings for .010 undersize journals.
Any ideas? and thnx. Fourdy |
check with vanpelt
Not to say they do not exist but I never heard of undersized journals. Usually the cam is just replaced. I know Schwalms makes or used to make brass inserts to resize the Model A block where the cast iron wore out. There are no cam bearings in a Model A. He would undercut the cam journals to get them to uniform size.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
It was a pretty common thing for some of the performance cam grinders to refinish the journals to be .010 under. Where I've seen it the most is when they took a steel 32 Billet cam core (which ran in the block - with no bearings) and reground it for a performance profile (think Potvin 425) - the journals would be ground .010 as part of the regrind process. I recently saw an original Winfield SU-1A with .010 journals. I always MIC every cam I put into an engine - to ensure that I don't make the mistake of putting a .010 cam into STD bearings . . . instant major loss of oil pressure and a cam "flopping around" in the bearings. |
#7 | |
They are also still available in .020" and .030" under! Thanks, Gary in N.Y. P.S. Just a tip but if you go down this path you MIGHT able to "build-in" the needed clearance, this can't always be done? This is a nicer way to do the build, "shoot" for .002"/.0025".
http://www.stromberg-bulletin.com/me...berg-equipped/ |
Gary, Have you found any New cam bearings under size. I was told my another builder he had .006 " cam clearance. Unfortunately it's not something i always chedk, I do now and find most oK. but some with as much as.003" Now, I find that most original cam bearings to be OK, surprising they don''t wear as much as we think. Don't build any more, but the track roadster will need balanced. Need a set of used 3 5/16X 3 3/4 forges pistons.
Take care Ron |
#9 | |
Ron give me a call I have a set of used Forged 3 5/16 by 3 3/4 stroke pistons. Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
I believe you will find that Fred Wilner at South Side Obsolete has those bearings. Barnfind08 here on the barn.
Thanks and I appreciate all your info.
Fourdy |
#12 | |
For years now we record EVERY hole size in EVERY block before we start any machining, this includes cyl bores, lifter bores, main bores, guide bores (in the Flatheads case), etc. These original sizes are all kept here on record for every build when it come in the door. This helps us determine any "pitfalls" we may encounter BEFORE we get into the actual build. Not sure what you mean (highlighted in red above), the .010" unders I spoke about above are for the journals that are either already .010" under OR "standard" journals that need to go undersize. If the cam journals are already .010" under and you use the appropriate brgs you will be locked into the oil clearance that you end up with, still cannot be fixed. If you plan on grinding the "standard" cam journals to .010" under you would FIRST order the .010" brgs, install them in the bores, measure the EXACT size using some type bore gauge THEN machine the journals to get the desired oil clearance. We like between .002" and .0025" generally speaking. Thanks, Gary in N.Y. P.S. I'm certain you know what I'm saying here and there really aren't many options as to correcting oil clearances in the cam brg area. Rods and mains have some easier fixes?
