Old 11-03-2017, 09:59 PM   #9
swoopNZ
MEMBER EMERITUS
Default Re: 1939 Column - Top Bushing Replace
If it's a coupe you may have to remove the LH rear window in order to get the horn rod out. It's that or drop the steering box.
1. Remove the light switch at the base of the steering column.
2. Remove the "c" retaining clip.
3. Remove the horn rod.
4. Undo the nut holding the steering wheel on.
5. Remove the steering wheel.
6. Remove the key from the steering shaft.
7. Make sure the ignition key is in the unlocked position.
8. Loosen the clamp at the base of the steering column.
9. Remove the steering column
I hope I haven't missed any steps - but at this age I never know.
You also might have to detach the column from it's dash mounting to give you a better angle.
Chris.NZ.
New Zealand.
swoopNZ is offline   Reply With Quote
