Old 10-24-2017, 09:07 PM   #1
Twocollies
Default early 30 cowl lights
did the cowl lights have a screw on the back of the early 1930 model A's or
were they a after market item. I have seen them at Hershey this year. I have an early 1930 coupe and I'm wondering if I passed up the opportunity to get a set.
Twocollies is offline   Reply With Quote
Old 10-24-2017, 09:40 PM   #2
CWPASADENA
CWPASADENA's Avatar
Default Re: early 30 cowl lights
I have a pair with a screw in the back. I always thought that they were early '30.
This is the only ones I had ever seen.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 10-24-2017, 10:37 PM   #3
Ed's Vickie
Ed's Vickie's Avatar
I have a set of them on my early (Feb.)1931 Victory Leatherback.
Ed's Vickie is offline   Reply With Quote
Old 10-25-2017, 08:13 AM   #4
Kevin in NJ
Brass arms and screw on the back.
I have an extra set I bought for the 30 town sedan I had and forget to send with the car.
Old 10-25-2017, 09:07 AM   #5
jrelliott
jrelliott's Avatar
The ones on my '28 have a screw on the back
Old 10-25-2017, 12:46 PM   #6
barnstuf
My 1997 Judging Standards page 15-2 in a chart at the top of the page indicates screw through March 1930, then riveted through August 1931. Leaves the assumption screw for late 1931 but does not clarify that period of time.
barnstuf is offline   Reply With Quote
Old 10-25-2017, 01:17 PM   #7
Don Turley
Don Turley's Avatar
"Model A Restoration Guidelines & Judging Standards", 2016 revisions, page 15-6: "With the introduction of the 1930 models, the cowl lamps had a shape similar to 1930-1931 head lamps and were stainless steel with chrome plated arms. They were standard equipment on deluxe body types and offered as accessories on other models. Early 1930 cowl lamps were assembled with a 10-32 oval head nickel plated screw through the rear of the shell. From April 1930, through the end of production, the lamp was assembled with a cadmium or zinc plated rivet instead of the screw at the rear of the lamp."
Don Turley is offline   Reply With Quote
Old 10-25-2017, 04:26 PM   #8
Twocollies
Thank you all. You guys have been very helpful
Old 10-25-2017, 04:37 PM   #9
NCRebel
NCRebel's Avatar
My '30 cowling lights have a screw. It holds the sleeve the bulb slips into firmly within the bowl of the lamp. I bet a rivet would be the only option.
A "gator" grip bracket inside the lamp bowl would be suspect as original.
NCRebel is offline   Reply With Quote
Old 10-26-2017, 12:14 PM   #10
asapguy
asapguy's Avatar
Don't the early cowl lights also have "Twolite" on the lenses??
asapguy is offline   Reply With Quote
