Old 10-22-2017, 04:11 PM   #6
newshirt
newshirt's Avatar
Default Re: Knocking after installing new flywheel
Originally Posted by Tom Endy View Post
If the clutch surface on the flywheel has been resurfaced a number of times it puts the surface closer to the flywheel mounting bolts. If excessive the springs in the clutch disk could be contacting the heads of the bolts.
Wouldn't I hear clicking when hand-cranking or turning the engine with the starter (with the clutch petal depressed)? It is completely clean. No bad sounds.
Ray White
newshirt is offline   Reply With Quote
