I looked in the past posts on tube shocks for info on these but did not see them ,so, if anyone has any comments on these I would appreciate it .
https://www.carid.com/1934-ford-mode...244220614.html Also need them for the rear . Thank you Bob |
Vintage parts is a part of the Hoffman group.
Bad low quality parts. You are better buying the shock kit from Pete and Jakes. |
Thanks Steve , The P & J kits look exactly like the vintage but slightly less expensive .
I am curious how the lower ends fasten ? Must slide over the existing posts but what secures them from shucking fore & aft ? |
This style of lower mount requires you to remove the hanger bolts and replacing them with a longer one.
NOTE: Stock perch is too short, must use #1042. • Extra long threaded stud fits any axle thickness (2″ or 2 1/4″). • Allows use of bolt-on lower shock mount #1067. • Eye is 3/4″ diameter. Last edited by JSeery; 10-19-2017 at 09:11 AM. |
As stated,you need a longer perch bolt.
Some perch bolts are keyed so the lower shock bracket can,t rotate |
Some of this is going to depend on how stock you are wanting to keep the front end. I know that the tube shocks are not original, but you can use later model parts or make them look like later models. The Pete and Jack ones that require the new perch bolts are not going to look stock. Many ways to go about the shock conversion, if you are interested in other approaches there have been several past threads on the topic.
Are these the perch bolts I will need ?
https://www.ebay.com/itm/Front-Sprin...bZb17Q&vxp=mtr Really don't care about keeping stock appearance , more so improved roadability . |
#9 | |
"Our part number is PNJ1042 They have extra threads to allow use with either 2 1/4" or 2" axle bosses and accept lower shock mounts." |
If you use tube shocks jack one side of the frame up until the wheels come
off the ground. Measure the length of where the shock mounts are or will be. Lower the car all the way down and measure where the shock mount will be at that point This is close to the stroke required for the tube shocks. Add about 2 or 3"s and this will be the stroke needed. If the stroke is not log enough it could pull the shocks apart. Also on rear shocks you don't want to much of an angle or it will shove the body to the right and left. I have seen this were it moved the body and frame far enough the old mounts cut into the tire. G.M.
www.fordcollector.com |
This is probably unnecessary, but it should be remembered that changing perch bolts can sometimes (?) be a daunting task.
Thanks guys --great info !
Tubman---yes , I think not a walk in the park ! When younger , I tackled almost any auto related task , but now @ 78 , not so anxious to dig out the creeper . |
