Old 10-17-2017, 11:14 AM   #4
DavidG
DavidG's Avatar
Default Re: Luggage with rumble seat or changeover to trunk
When properly installed, both the bottom and back rumble cushions are fixed in place and don't move around in use. There's room for several suit cases on the floor (which is thankfully basically flat) between the front seat back and the rumble bottom cushion. Inserting them into the available space and retrieving them does require some thought and a bit of gymnastics, but definitely doable.
You cannot, however, place anything beyond a bit of printed material on top of the bottom rumble cushion and close the rumble lid.
