Old 10-11-2017, 08:40 PM   #1
john_gto
Default Generator detail question
Hi all
I have questions regarding two different generators as shown below:
1) top three photos appear to be from a L1 type based on the end plate and 7/8"nose
- does it have the correct front plate ? it is aluminum and the bolt head area is recessed
2) bottom 3 photos are from a generator I picked up at Hershey - it has an aluminum rear plate - non vented and is chamfered at the end - I am unable to find it in the JS or searches here - anyone know any details about it ?
Thank you for any replies and I have already learned a lot from this site.
John
john_gto is offline   Reply With Quote
Old 10-11-2017, 09:13 PM   #2
larrys40
Default Re: Generator detail question
John,
I believe the front aluminum is a 32-34 4-cyl and/or service replacement front cover. Same with the aluminum rear on the lower photos.
I an not 100% but hopefully someone else will chime for additional info.
thanks,
Larry
larrys40 is offline   Reply With Quote
Old 10-11-2017, 09:16 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Pictures 1 and 5 showing the aluminum end plate and beveled end plate are both post Model A production, as are any bodies with 2 wires coming out of a rubber grommet, instead of a stud for the output.
Old 10-12-2017, 04:37 AM   #4
john_gto
Thank you Larry and Tom
The first generator ( top 3 pics) does have the two wires and rubber grommet instead of the post .
Old 10-12-2017, 04:08 PM   #5
john_gto
Would it be more correct to put the two aluminum ends on the generator with the two wires coming out the grommet and the later pulley?
Old 10-12-2017, 11:13 PM   #6
Tom Wesenberg
Yes
