Old 08-28-2017, 11:46 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Tubeless bias on stock rim
IMO pull out the tubes ,seal around the rivets with good silicone and use the correct valve stem.Done this several times(with radials) with no problems.I don't imagine that bias tubless would give you problems.
