Old 08-25-2017, 03:02 PM   #6
Bruce Lancaster
Default Re: 8BA Fuel pump quandry
Why not just hook up the gravity tank again and see if you have the leak still? That will speedily tell you if pump is the problem.
Also check pressure...I've heard of new flathead pumps coming through with 7 pound diaphragm springs from much later model applications. I have no idea if that could apply to Airtex, but I'd sure check.
