Old 08-17-2017, 02:12 PM   #6
Bruce Lancaster
Default Re: Why Hot Ignition Key??
Pretty sure you have (assuming Ford type lock and switch) a repro switch body. Bad contacts heat it up and the badly chosen plastic softens enough for the contacts to sink in...go get the original, open it up, and clean and polish everything.
