Old 08-15-2017, 02:44 PM   #1
LeonardS
Default What model is this Ford Carburetor from?
Does anyone recognize this Ford Carburetor and what year/model it's from?
LeonardS is offline   Reply With Quote
Old 08-15-2017, 02:52 PM   #2
Bob C
Default Re: What model is this Ford Carburetor from?
6cyl
Bob
Old 08-15-2017, 02:52 PM   #3
LeonardS
Any idea what year?
Old 08-15-2017, 02:54 PM   #4
skidmarks
skidmarks's Avatar
Looks like a H motor, 47 to 51 going by the vacuum port but it looks big.. Might also work on the 215, not sure which carburetor they used
skidmarks is online now   Reply With Quote
Old 08-15-2017, 03:02 PM   #5
LeonardS
Could it be from an early T-Bird? The guy I bought a bunch of parts from, had T-Birds.
Old 08-15-2017, 03:08 PM   #6
FRANK PKNY
FRANK PKNY's Avatar
Not a t-bird . Is there ant number on the float side ?
FRANK PKNY is offline   Reply With Quote
Old 08-15-2017, 04:34 PM   #7
LeonardS
No, there are no numbers that I can see.
Old 08-15-2017, 05:53 PM   #8
rotorwrench
rotorwrench's Avatar
Too much paint on it. There might be numbers under the paint. The 226 H with a load-o-matic judging by the vacuum port.
The 215 used the glass bowl Holley.
Old 08-15-2017, 07:44 PM   #9
LeonardS
I'll clean it up and see if I can find any numbers.
Old 08-15-2017, 08:13 PM   #10
DD931
DD931's Avatar
I don't think it's for an H engine, though. Looking at a 7HT carb for my '48 F-1 with an H engine, the vacuum port is smaller and is halfway up the lower aluminum section - not in the cast iron bottom. It is threaded into the aluminum and doesn't have a brass fitting. And it comes in straight from the side, not at an angle. There is a boss in that area, but it's not drilled. Also, the idle jet screw is located in a slightly different location where there is no boss on my carb. There may be a model designation on the opposite side of the float bowl from the Ford script, although there's nothing visible in the pics. So, I'd be suspicious of an H engine application since the location of the vacuum port will have a major impact on the operation of the Loadomatic distributor. At any rate, it should be compared with a G series carb to confirm my observations. If it's for an H, it's for a passenger car, since the trucks have a different top. Hope I haven't confused the issue!! I'm interested in the comments from others!!
DD931 is offline   Reply With Quote
Old 08-15-2017, 08:23 PM   #11
DD931
DD931's Avatar
Try posting these pics on the Early V8 web site where Ken CT can see them.
Old 08-15-2017, 11:46 PM   #12
Ian NZ
Ian NZ's Avatar
That carburetor is a Holley 847, fitted to the Ford 1941 -1947 6cyl engines.
Photos show one fitted to a 1932 Ford V8 Engine and they work very well too.
Ian NZ is offline   Reply With Quote
Old 08-16-2017, 10:38 AM   #13
rotorwrench
Most of the early Ford G 6-cylinder carbs (1GA) don't use a vacuum port since they had the old style vacuum brake distributor. The 5GA might have that port but I don't know for sure since I can't find one. I found an H type for Load-O-Matic set up that has the port relocated higher up on the body so it could use venturi vacuum instead of manifold vacuum. It may be a connection for a Southwind heater or maybe windshield wiper. It also may have been for industrial use. The 4-cylinder carbs were usually side or updraft types for those few 9N pickups with a 4-banger.
Old 08-16-2017, 06:09 PM   #14
LeonardS
If anyone needs this carb, I would make you a good deal!
