01-28-2011, 02:52 PM | #1 |
32 vs 34 cab
what differences are there between the 32 ford b cab and the ford 33-34 1/2 ton truck cab? size, moldings, mounts, etc.? thanks
01-28-2011, 03:07 PM | #2 |
Re: 32 vs 34 cab
For one the Firewall in the 32 is different and removable.Dash is different.32 has opening for the guage tunnel.
01-28-2011, 05:26 PM | #3 |
Re: 32 vs 34 cab
Hi; 32 cabs have some odd points: early 32's have reveal indents where the door edge closes, The tops are welded on the A pillars and the seam leaded, The tops DO NOT have a reinforcing ridge near the visor, some visors DO NOT have a center reinforcing brace, Cowl vents are early/late angles, ALL 32's have under seat gas tanks/ Split seat bottoms. Door hinges DO NOT have reveals around the hinge openings. These are just what I can remember. Join Early ford V8er's Newc
01-28-2011, 05:51 PM | #4 |
Re: 32 vs 34 cab
'34 Cabs have an extra wide belt line across the back of the cab
01-28-2011, 10:51 PM | #5 |
Re: 32 vs 34 cab
Here's some good info on how to tell the two apart:
http://www.fordgarage.com/pages/cabidentification.htm Ah Vince, what would we do without him keep V-8ing and 4-banging!
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. |
01-29-2011, 12:59 PM | #6 |
Re: 32 vs 34 cab
01-29-2011, 01:20 PM | #7 |
Re: 32 vs 34 cab
01-30-2011, 07:49 AM | #8 | |
Re: 32 vs 34 cab
Late 32 cabs do have the reinforcing bead near the visor.HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell |
