Old 07-28-2017, 06:31 AM   #1
Mike
Mike's Avatar
Default Adjustable drag link
Good morning, does any of the venders sell adjustable drag links?
mike
Mike is offline   Reply With Quote
Old 07-28-2017, 09:14 AM   #2
texas webb
Default Re: Adjustable drag link
THink I saw one in the Model A swap for sale here.
texas webb is offline   Reply With Quote
Old 07-28-2017, 09:52 AM   #3
Brian T
Brian T's Avatar
mike
Mike , check your PMs,
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 07-28-2017, 10:18 AM   #4
Keith True
Keith True's Avatar
I see a lot of people asking about adjustable drag links,but I still can't see why they are needed.The steering wheel was not centered when the car was built new,so why does it need to be centered now? Ford put two keyways in the wheel when it was made,and the service bulletins tell you to pull the wheel off and install using the other keyway if a spoke blocks the speedo.I have four A's sitting here right now that we are looking at.Two have shortened pitman arms and the arms on both hang down perfectly straight.On the two cars with stock arms one hangs down a little to the front,and the other a little to the rear.I know in theory the change in a short pitman arm comes out to be in thousandths,but does it make any real life difference in driving? With a bunch of other steering modifications I can see it being needed,but is it needed on a stock A?
Old 07-28-2017, 10:59 AM   #5
johnbuckley
johnbuckley's Avatar
Originally Posted by Keith True View Post
....adjustable drag links,but I still can't see why they are needed......
One good reason for them in the UK is it will fit both LHD and RHD cars!
Old 07-28-2017, 11:09 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with Keith, and don't see a real need for one.
I'm thinking of buying the short pitman arm, mainly to take some load off the tank bracket.
Old 07-28-2017, 11:30 AM   #7
Bob C
I think the problem is the steering gear is adjusted and the play is taken out in the
centered position and when using the shortened pitman arm the gear is not in the centered position when driving down the road. You need the adjustable drag link to correct this. Clear as mud?
Bob
Old 07-28-2017, 03:37 PM   #8
Brian T
Brian T's Avatar
Bob C is correct, it really shows up if you have a 7 tooth steering box, I have posted about this several times with along with a picture, It really needs to be shown with a schematic drawing to see what is effected, to add vision to the subject someday I will do this.
Old 07-28-2017, 03:39 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
I think they offer the adjustable drag link is to appease the anal-retentive ones in the group.
Old 07-28-2017, 05:41 PM   #10
hardtimes
hardtimes's Avatar
mike
Hey Mike,
Haven't seen a vendor offered one.
You can make your own as I did.
To make one, you do need the die that makes the thread that you do not have. Example, if you have used/or new tie rod, cut it to length needed. You will have two halves. Each end needs right and left hand thread. I bought the left hand thread die. If seems that the right hand thread die is cheaper and more available. You can make the drag link with an 'adjuster' in the middle also...easier to adjust , IMO.
Old 07-28-2017, 05:58 PM   #11
old victoria
trying to post pictures of the draglink I make (all cnc) turtle pool not inc.
old victoria is offline   Reply With Quote
Old 07-28-2017, 06:39 PM   #12
taffrail
taffrail's Avatar
I have a 1930 tudor with a shortened pitman arm, the spoke stayed right in middle. I hadn't thought about the benefit of less pressure on the tank bracket. It does steer easier. I have CCPU and the spoke space is in middle, thought maybe it was a car-truck thing.
taffrail is offline   Reply With Quote
Old 07-28-2017, 07:21 PM   #13
quickchange
quickchange's Avatar
A brand new short Right Hand drive pitman arm is available from Arizona Model A for those in the other 1/2 of the world, & Antique Ford Parts IN NZ.
quickchange is offline   Reply With Quote
Old 07-28-2017, 07:31 PM   #14
daveymc29
daveymc29's Avatar
I have two A's with the shorter pitman arms. Not modified originals but the shorter ones sold by Snyder's and Bratton's. Neither is because I am too lazy to turn the wheel. Both are because I have arthritis and it hurts my hands to drive with the longer arm. this is just enough relief that I can drive all day without ending up in agony. Doesn't affect the turning radius at all, as the nut on the kingpin locking bolt is still your limiting factor, though it takes a little more turning to get there. Works for me, not for purists.
daveymc29 is offline   Reply With Quote
Old 07-28-2017, 07:55 PM   #15
CarlG
CarlG's Avatar
I have one of Old Victoria's adjustable drag links. Dave is an excellent machinist. Worth every cent.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-29-2017, 08:00 AM   #16
Mike
Mike's Avatar
Thank you all for the info.
Mike
Old 01-20-2023, 03:29 PM   #17
tgreen03
Hi, what is the price on your adjustable drag link?
tgreen03 is offline   Reply With Quote
