I have this as a spare but I'm spring cleaning and don't think I'll ever use it.
It looks just like my Sparton horn. That one looks VERY clean and nice.
Doug in Waterloo |
Would you be interested in selling it.
There should be an ID on the area where the bolts connect it together. Steward Warner, Ames, etc had stamping in the flat area at the bottom. If there are not 2 small rivet holes in the motor cover or a plate riveted to to it, it isn't a Sparton. If you have a copy of the Judging Standards, there is a section 19 that describes all the features of the various horned used on model A's.
Rusty Nelson |
Measure the width of the frame and motor shaft and look here:
https://sites.google.com/site/mrtexa...s/home/idhorns
41 woodie https://41fordwoodie.weebly.com/ |
I made a little video ; https://www.youtube.com/watch?v=dOjKTPaDsOA |
#7 | |
it looks to be a Sparton. but who ever put it together put the plug connection together wrong.
And the bracket is installed incorrectly
I made a little video; https://www.youtube.com/watch?v=dOjKTPaDsOA
Sounds like it needs a little tuning. First I would grease the ratchet as it seems the motor is stopping too soon. Then try adjusting the screw one click at a time in and out and see what sounds best. Some new gaskets are too thick, and that can affect the sound. Ensure the diaphragm is clocked properly with the drain hole at 6 o’clock.
I Love Anything That Turns Money Into Noise |
Notice the brush screws,
Recessed are Sparton, proud are Stewart Warner;
Looks to be an Ames.
1.250 (actually a little larger and not consistent from both sides and top) of motor bracket, and a .3125 shaft.
#13 |
#14 |
The video actually doesn't do it justice, sounds better in person. I took it apart and added a little grease to the ratchet and assembled the electrical connection insulators properly.
#15 |
Your horn sounds like mine which is also a Ames. There are 3 locations usually with the Ames diamond shape stamped on it all of which I wouldn't bother scratching that nice paint off. I found doubling the gaskets supplied from the vendors help the sound quite a bit. It would be a good idea to put a drop of locktite on the bolts holding the horn to the bracket, I experienced that problem and nearly lost my horn.
#16 |
she sounds beautiful. No sick cows there!
#17 |
That horn sounds perfect!
#18 |
Suppose it's worth $200?
#19 |
Art our Maine Coon Tomcat makes that same sound
#20 |
