#16 |
I have taken it off now - see the attached 3 pics. There is a very small amount of grease on the spindle (the spindle is that small cog, right?) and plenty on the helix but there does not appear to be any grease on the ring gear. Can you see anything in the photos that indicate the cause of it sticking? The shaft does not appear bent when I rotate it.
