Old 05-12-2017, 06:31 AM   #1
cosmo
Default flathead issues
Blew the head gasket #4 on my 8BA engine with aluminum heads. Had antifreeze pouring out the exhaust. Replaced head gasket using copper, Used thread sealent on bolt threads retorqed to 50# all acrording to the book. Engine runs great now but when it comes down to idle alittle white exhaust starts coming out the tailpipe. I don't notice it when driving down the road, only at idle. Any ideas? Thanks, Dave
cosmo is offline   Reply With Quote
Old 05-12-2017, 06:49 AM   #2
Henry/Kokomo
Henry/Kokomo's Avatar
Default Re: flathead issues
Warped head? Cracked block? Wavy deck on the block? Would have to do some accurate measuring / checking to tell for sure.. Good luck.
Henry
Henry/Kokomo is offline   Reply With Quote
Old 05-12-2017, 06:55 AM   #3
Phil Gillespie
Phil Gillespie's Avatar
Have you been through 3 torque cycles oon heads. Maybe try another torque cycle first.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 05-12-2017, 08:02 AM   #4
JSeery
JSeery's Avatar
As Henry stated, if you didn't check the heads, block mating surface or inspect for cracks, it will be very difficult to determine what the issue might be now.
Old 05-12-2017, 07:51 PM   #5
Binx
You could have a coolant pool in your muffler that needs to be cooked off with a long drive.
Lonnie
Binx is offline   Reply With Quote
Old 05-13-2017, 05:51 AM   #6
Frank Miller
Frank Miller's Avatar
Could benormal exhaust condensation. As someone said, try retorquing and then run for a while to see if you're losing coolant.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 05-13-2017, 06:28 AM   #7
cosmo
I went through the 3 torque cycles trying to do everything right. Exhaust was full of antifreeze. Engine is cooling great, level in radiator is not dropping, oil is clean. Just seems not right to do this in idle. Will get out this weekend and drive. Thanks!!
Old 05-13-2017, 08:34 AM   #8
37 Cab
37 Cab's Avatar
Might use a block test Kit to see if there are hydrocarbons in the cooling system. Nice tool for small leaks that are not obvious.
https://www.napaonline.com/en/p/BK_7001006
Tommy
37 Cab is offline   Reply With Quote
Old 05-13-2017, 09:46 AM   #9
chap52
chap52's Avatar
Opening a can of worms, but I would think that composite head gaskets would be more apt to seal small imperfections in deck or head.
Here is a video of how a head can be surfaced at home.
Maybe I've opened two cans of worms. You decide!
https://www.youtube.com/watch?v=SK2R2LdkLKs
Old 05-13-2017, 10:41 AM   #10
19Fordy
19Fordy's Avatar
No, you didn't open a can of worms. In many of the poorer countries in the world where you have to "make do" this is the way it's done.
19Fordy is online now   Reply With Quote
Old 05-13-2017, 10:46 AM   #11
rotorwrench
rotorwrench's Avatar
Cracks in the exhaust valve bowls can be slow seepers. The center deck area it right above the siamese exhaust port and can crack in the center bolt bore area down into the port causing a slow seeper.
If the head gasket is holding its mud then a person might try some Bars leaks but the stuff can also plug up things you don't want plugged at times. If your radiator is old and partially crudded up, the sealers can finish off the plug.
