Old 05-12-2017, 06:44 PM   #18
Synchro909
Synchro909's Avatar
Default Re: Seeping fuel tank at the column mount
My answer to those concerned about a tank exploding while they are soldering it is firstly, soldering won't get hot enough to cause ignition and secondly, from school science classes when I was about 14 years old, combustion needs 3 things to happen ALL AT ONCE. They are the presence of fuel, oxygen and a source of ignition. (You'd have the ignition temperatures if you were welding.) If any one of those things is missing, combustion - read explosion, can't happen. The easiest one to eliminate is oxygen and the easiest way to do that in this scenario is to have an engine running nearby and run a hose from its exhaust into the tank. With the motor running, the tank is full of exhaust fumes, which we know are devoid of oxygen. Run the motor for a few minutes before starting to weld and don't breathe the exhaust.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
