Old 04-30-2017, 05:03 PM   #1
pooch
pooch's Avatar
Default 239 bore.
If a standard piston is 3.185, what is the optimum bore size at bottom of cylinder ?
How much wear at bottom and how much taper is allowable at top of bore for just a reasonable runnning engine that will never see a lot of miles.
ie, fitting new pistons into an existing bore.
pooch is offline   Reply With Quote
Old 04-30-2017, 05:40 PM   #2
JSeery
JSeery's Avatar
Default Re: 239 bore.
I don't know the specs off the top of my head, but there are several things to consider. Taper, how egg shaped/out of round the bore is, ridge at top of the cylinder, etc. Ridge must be removed or there is a good chance of breaking the top ring.
Per Repair Manual, Ford, Mercury & Truck, V8 Engines, 1937 to 1947, Ford Motor Company, July 7, 1947:
Ware limits
Bore out of round - .003 max
Bore taper - .006 max
Bore ware - .006 max
Piston to bore - .005 thickness gauge 1/2 wide 6 to 10 lbs pull
Old 04-30-2017, 08:09 PM   #3
Anteek29
Anteek29's Avatar
Side note: I thought the 3.187 bore was for a 221 cube flattie? A 239 flattie would have 3.375 bore? Correct?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 04-30-2017, 08:11 PM   #4
Anteek29
Anteek29's Avatar
OOPS...I was waaay wrong - sorry!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 04-30-2017, 09:38 PM   #5
WestCoast
a 239 stock engine is 3 3/16" inch bore (3 /.187") using hasting steel vent rings I have gone way past the books engine tolerance specs, ran strong and no smoke, good for around 40,000 miles
WestCoast is offline   Reply With Quote
Old 04-30-2017, 10:17 PM   #6
Ol' Ron
Ol' Ron's Avatar
The auto-thermic pistons can be set to .0015/.002 skirt to wall clearance. This style piston was commonly used from 45/53, and most replacement pistons for the 39 up are of this style. Not sure of the early pistons. .006 is alittle much.
Old 04-30-2017, 10:30 PM   #7
quickchange34
quickchange34's Avatar
You need to use a bore gauge and check the taper in the bores frist If you have 6th taper all you are doing by putting new pistons and rings in is adding a band aid to the problem.
quickchange34 is offline   Reply With Quote
Old 05-01-2017, 07:10 AM   #8
Frank Miller
Frank Miller's Avatar
As a quick inspection, see how much ridge there is at the top. As someone said you need to remove it to prevent breaking rings. Wear typically occurs more at the top due to the ring pressure. Someone said with just new rings you're putting a band aid on it but if funds are lacking and you just want it to run reasonably well, new rings may do what you need. If this is an 8ba and this far apart, new bearings might also be a good idea.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 05-01-2017, 08:06 AM   #9
Ronnie
Ronnie's Avatar
To get a close idea of your taper all that is required is square up one of your existing rings in the bottom of the bore and measure the end gap.Do that three times starting at the bottom then half way up and last at the top under the ridge compare your findings as to end gap and you can calculate the taper as the end gap increases with the formula of PI. Every .001" increase in bore will give an increase of .00314" end gap.
R
Ronnie is offline   Reply With Quote
Old 05-01-2017, 08:37 AM   #10
JSeery
JSeery's Avatar
Interesting approach Ronnie.
Old 05-01-2017, 08:53 AM   #11
Ronnie
Ronnie's Avatar
Not my first rodeo It does work and you know where I learned that don't you "lol"
R
Old 05-01-2017, 09:03 AM   #12
cmbrucew
cmbrucew's Avatar
R
Why didn't I think of that. Trying to get my big hands, and an inside mic just right is a chore I can do without.
Thanks Ronnie
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 05-01-2017, 09:43 AM   #13
Curt in AZ
Curt in AZ's Avatar
I use the same technique as Ronnie. Probably obvious but use a piston to push the ring into position to make certain it's square in the bore.
Curt in AZ is offline   Reply With Quote
Old 05-01-2017, 01:10 PM   #14
JSeery
JSeery's Avatar
R
I'm spoiled, I always get someone to loan me a bore gauge! I don't like telescope gauges myself, to hard to get consistent readings.
Old 05-01-2017, 02:00 PM   #15
Bored&Stroked
Bored&Stroked's Avatar
Exactly! And a good 3 point bore gauge - not one of the el-cheapo ones . . . thy typically cost over $1000 new!
Bored&Stroked is online now   Reply With Quote
Old 05-01-2017, 02:07 PM   #16
flatheadmurre
flatheadmurre's Avatar
The setting gauge for the bore gauge isnīt a to fun investment either...but if you canīt trust what you measure itīs not much good either.
Old 05-01-2017, 04:16 PM   #17
Ronnie
Ronnie's Avatar
First you need to be consistent.I have grown up using measuring equipment.Telescope measuring is a good way to get a measurement but then you need a micrometer to read the gauge.You now have 2 investments.Most non machinist people don't know how to use a telescoping gauge.I have seen some struggling and not liking the results.It takes 10 seconds to get the size done.If you are fiddling around you are doing it wrong.
R
Old 05-01-2017, 08:29 PM   #18
Bored&Stroked
R
Yes - and I have used them a plenty. But when you're trying to measure the bore of something - especially a LONG cylinder, it is sure nice to have a precision dial bore gauge . . . that you can slide up/down the bore - then switch to a 90 degree location and do it again . . . just can't beat it. (Now that is just one mans opinion!). Same goes for measuring the mains on an engine - using a LONG dial bore gauge that makes it easy to start on #1 and work your way back.
Old 05-02-2017, 02:10 AM   #19
pooch
pooch's Avatar
Ronnie, thanks for good trick.
Frank, absolutely zero ridge , I cannot understand it on a standard bore.
Block is in shop now to get a guy to measure bore.
Have another Q, are (mushroom) intake and exhaust valves identical ?
I have a box of stainless valves that look almost new here.
Are these Ok to use in a standard block ? ie no hardened seats .
Old 05-02-2017, 08:59 PM   #20
Bored&Stroked
I've always seen different valves for intakes versus exhausts from the factory in all the 32-48 engines (from the factory). Now, I'm sure there are many cases where this doesn't hold up - but generally it was true.
With that said - I've taken apart many rebuilt flatheads where all sorts of intake versus exhaust combinations were used - so I don't know if it actually makes any difference. I don't know if there were different alloys or material properties between the two different valves from Ford.
Anybody know the details?
B&S
