Old 04-27-2017, 04:19 PM   #6
rotorwrench
rotorwrench's Avatar
Default Re: Help. Loosing Coolant
Ya, that can be a problem with bar's leaks too. It can further plug an already gummed up radiator. If it's an engine block leaker and the radiator is otherwise clear then it might work OK though. You can set up a catch bottle for the radiator overflow using an old soda bottle and see if its barfing out there.
