I have an 8" rear and disc brakes front that require a 2 3/4 pilot hole in the wheels. I measure the stock pilot hole to be 2 5/8". Aftermarket wheels seem to center with the lug nuts. Can these original wheels be opened with a die grinder to clear the hubs and rely on the lugs to center them? Are there later Ford wheels with similar backspacing and larger pilot bore? Thanks for any tips. Gene
I would NOT remove metal from the center hole.
Most all wheels for medium and full size Fords made in 1968 or 1969 and newer have the 2.75" center hole. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I got the rear-end put in the recliner, and now I'm going to rest up & watch TV.
I had new Granada hub/rotors turned down to fit the wheels. There is plenty of meat on the hub, so that little bit didn't hurt at all.
That is what was recommended by racer dave. My rear is an 8", so the axle stub is 2 3/4" also. I haven't found an aftermarket wheel yet with enough backspacing. I'm still looking.
You might try these guys. Some years ago they put 55 ford centers in 7" rims for me, 4" backspace to mount a set of 10" cheater slicks. At that time they were also pretty knowledgeable about what centers or rims would let you mount the original hubcaps, or whatever you're using. Still worth a phone call.
http://www.thewheelsmith.net We've also got a couple local guys who do wheel repair on new fancy wheels when you hit a curb and bend them. The one near me does a lot of dealer work on trade ins. But he can also relocate the center in the rim for the correct backspace. He's all set up to check the run out and do it right. How much backspace do you need? |
Isn't that a 10" wide tire? Sounds like an 8/8.5 tire would fit better.
I think offset and backspace are measured from the bead surface, not the outer rim. As well as wheel width. You might double check that before you order anything.
Also, if the front suspension is what I think it is, 3 1/2" front backspace is the most you can use and clear the upper ball joint. The picture below is the upper ball joint and a 225/60 15, 3 1/2" backspace. There's a ball joint mod, but it didn't effect this measurement. Hmmm, won't let me attach the photo. Last edited by miker98038; 04-25-2017 at 01:16 PM. |
Upper ball joint.
#10 | ||
wheel measuring image
I stand corrected. Been a while since I measured any wheels. It's "offset" only that measures off the rim width.
https://www.tirerack.com/wheels/tech...jsp?techid=101 |
#13 |
we all need a refresher at some time
