Old 04-15-2017, 12:52 PM   #5
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: coil positive ground
Some bad info here !!! Once a coil has been ran in a given polarity , it shouldnt be reversed.
The steel laminations in the coil will retain some magnetism and interfere when polarity is reversed. Incorrect polarity can loose 80% of its power when wired incorrectly...
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
