Hi Jim, I use the marc mafca color chip book as a standard the newest one the chips are big enough to read with a rapid match camera. ppg does have model A offset colors, call the color library they should be able to tell you a code. I have the offset codes at home I will look and see what it says tonight. but most of the colors need to be tinted and sprayed out to match standard hope this helps
