Old 04-03-2017, 03:51 PM   #1
37don
Default Cleaning aluminum heads
I have my heads off my 276 after 40000 mi and they needed to be cleaned. Not to dirty but discoloration from heat and exposure has taken them down a notch or two. I tried all the home remedies and wheel cleaners on the first head and it still had that used look. After a lot of time on the internet I tried Mac aluminum brighter on the second head and after just one try the head looks like new again.
I noticed that where I didn't spray the cleaner it left random streaks where it ran down the side of the head. I wet the head and then just sprayed the product on and let it set for about a minute. I have a soft brass brush from harbor freight and just ran it between the fins and what a difference. When done just rinse them off real good because this stuff is an acid base.It is a napa product and not expensive. $6.00 for a spray bottle or $18.00 for a gallon.I will do the other head as you can see the difference between the heads.
Will update when I have them both done. Use protective gear when using this stuff as it has phosphoric acid in it.
Regards, Don
37don is offline   Reply With Quote
Old 04-03-2017, 06:07 PM   #2
Capt Kirk
Capt Kirk's Avatar
Default Re: Cleaning aluminum heads
When I was driving semi, the boss would buy gallons of aluminum brightener. I think it was commercial stuff. Spray it on and let it soak for a bit and then rinse off. It left a clean mat aluminum finish which was a good start for me. I liked my truck to have polished aluminum so after the acid treatment I went to town with the buffer and rubbing compound...spent hours! I once did the grill on my Pete and didn't want to spray so I rubbed it in with unprotected hands...big mistake!!! Wear gloves and eye protection...the stuff is nasty but does a good job. If you like a mat aluminum finish then you're done...if you like polished then you're on your way.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 04-03-2017, 07:49 PM   #3
RB
RB's Avatar
I used alum mag wheel cleaner applied & rinsed until desired cleanliness & final rinsed with baking soda solution
RB is offline   Reply With Quote
