03-27-2017, 06:51 AM | #1 |
Valve retaining clip
I have removed all the valves on this 37 engine no problems except the last one no. 7 intake clip Just won't come out, It's very loose but won't pop out. I've tried tapping it above the clip, yes I have made a wire puller, even have a heavier hook ( radiatior hose remover) squirted it, tapped this way, that way but it won't come off the guide. I'm worried if I keep working it I'll snap the tag of and then I'll really be in trouble.. Should I just try take the cam out and will the lifter just fall out and keep at it ? Any further tricks?? Frustrated..
"Came too close to dying to stop living now!" |
03-27-2017, 07:29 AM | #2 |
Re: Valve retaining clip
with that valve up you should be able to reach the top of valve guide with a small drift pin. drive guide down a hair and clip will come out. you are lucky you have only one stuck as i have seen motors in which i could get only one out!
03-27-2017, 06:34 PM | #3 |
Ok, think I got what you mean..
03-27-2017, 09:05 PM | #4 |
Are you repairing a running engine or stripping a block for a rebuild? Some removal methods are more aggressive than others. I just bought NORS exhaust valves for 8 bucks apiece.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
03-27-2017, 11:12 PM | #5 |
I am stripping everything however all the parts are serviceable so I don't want to butcher anything..
Geez where did all the engine builders go today ..??
03-27-2017, 11:42 PM | #6 |
03-27-2017, 11:51 PM | #7 |
suppooooosably you can put wood wedges in to retain the spring/valves and pull the cam, turn the block over so the lifter is down, so i've heard.... I wouldn't pull the cam without retaining or removing the springs.
A spare ford horseshoe clip wouldn't be difficult here to find. ....With that said and being one valve. Flip the block and use a valve fork to compress the spring. Then have someone pull the cam out. done. or one of these... . Last edited by Tinker; 03-28-2017 at 12:29 AM. |
03-28-2017, 01:39 AM | #8 |
I have a mate that has something similar that sneaks behind the valve, but I couldn't quite get how you lift the valve up far enough to get it behind?? Frustrating as I have given it a decent tug and that damn clip wont pop out, loose as but ...nup! I'll have another crack when I get home .
03-28-2017, 02:39 AM | #9 |
You take the keeper on the bottom out and then the valve comes up enough to get guide driver in.
Tap the guide down a bit to get the horseshoe clip out. If you got all the rest of them out that easy you should buy a lottery ticket...your on a roll !! Half of mine takes a plasmatorch and boltcutter to get apart. |
03-28-2017, 07:13 AM | #10 |
Got it! Had another crack at it used the heavier hook bent it out of shape a bit but it eventually popped out, all good.
So now the next stage of the engine build... Stay tuned!
