Old 03-24-2017, 11:19 PM   #13
Binx
Default Re: Oil pump Old or new Melling
I have a Melling from the 1980s that isn't machined right and literally drops into the block so compare (mic) the ford pump to the melling if you go that route. If you want to rebuild the ford pump with a kit, only use a genuine melling kit. There are others cheaper but reportedly cause gear binding.
Lonnie
Binx is offline   Reply With Quote
