03-17-2017, 09:35 AM | #1 |
What would cause this?
Pictured is the back half of a two-piece pulls I removed from an engine that had been running and not leaking out the front crank seal. What would cause the severe wear on essentially only one-half of the unit? Bent crank end? I wonder what the timing gear would look like? Any ideas?
03-17-2017, 09:37 AM | #2 |
Re: What would cause this?
more pics
03-17-2017, 09:43 AM | #3 |
"Maybe" it was NOT engaged in the crank gear key & was sitting CROOKEDY?
Bill W.
03-17-2017, 10:18 AM | #4 |
Maybe engine mains off center? Maybe the is not square? It looks like new compared to mine that I replace, the ears on mine where broken!
03-17-2017, 10:27 AM | #5 |
Yea could be any number of things, check to make sure your crank isnt a hair bent by checking run out but could be incorrectly made part from the get go. Ive heard some of those older 2 piece designs were iffy at best.
Could be worn out front main I suppose too but you would think you would have heard that.
03-17-2017, 11:08 AM | #6 | |
lathe and check the run out of the OD. Clean it first to get an accurate reading. You need to do this with a dial indicator.. |
03-17-2017, 11:12 AM | #7 |
looks like it might have been loose
03-17-2017, 02:16 PM | #8 |
Post #6 has the answer, and if the outside diameter is not aligned with the inside diameter, true it up on the lathe.
