I've done several and think I did it different every time. The divider needs to be loosened and/or removed. There is a screw in the door channel at the top and nut/bolt inside the door.
I've had regulators out for refurbishing but I don't believe it is necessary to get the glass changed. Disconnect the channel from the two points and it should come down and out. If my memory is lagging someone will be along to set us straight. |
