Old 03-08-2017, 03:39 PM   #35
Solo_909
Default Re: What's the difference between these wheels?
Originally Posted by V8COOPMAN View Post
Solo.........This is a picture of another '41 Merc. As Chris said above, all of the 16"-ers pretty much look the same. The only difference with the later pick-up wheels that Chris talks about is that those five narrow, deeply-stamped rectangles just outboard of each stud hole probably will not appear to be stamped quite as deeply in the later pick-up wheel center. Otherwise, they appear the same. The last year for the pick-up wheels with the "innie" nubs for the early hub caps was '66. DD
Gotcha, yeah I really like the deep stamped wheels better. I figured there was something different. I would love the 41 mercs but like you said they're hard to find. I have some 16" 4.5's lined up so hopefully that works out.
Solo_909 is offline   Reply With Quote
